PowerPoint Experts Question Add On Programs
Status
Not open for further replies.
Pixle
435
Projection screen shows slide show but you can see the presentation on the computer with slides
Hey im looking for a program that is used with powerpoint that lets you view your slide show slides on the computer but when its projected onto the projection screen it shows only the presentation.
Could someone please tell me of any programs that allow powerpoint to do this? please
Please do not have two threads in different forums on the same subject
Senior Anandtech Moderator
Common Courtesy
Pixle
435
How would I use a dual screen, Id need a special adapter for the pc? Anything else I would need cables or use a pc with 2 vga outputs and connect two monitors would that work? and have it play on one monitor? but what about the other monitor which will the presentation show on?
thanks so much fleshlight its for a court presentation.
Oct 25, 2006
11,036
11
If you use a laptop its easy
Just hook the projector to the laptop, and set it as a secondary monitor. Voila. You have 2 screens. You can keep botes on your laptop screen while dragging over PowerPoint to the projector screen.
Its the same with a desktop, though you will need a splitter.
Pixle
435
so i click view slide show after i move it to the first monitor and keep my laptop on the second monitor
right click on desktop properties > settings screens
thanks tenshodo13
kranky
156
And once you have the two screens set up on the PC, remember to enable "Presenter View" in Powerpoint itself.
Status
