PowerLite Cinema 200 (720P) Cheapest bulbs, lens shift, the works
Status
Not open for further replies.
Linkage
* FREE Ground Shipping for a limited time
* Rich feature set
* Exceptional image quality
* Native 720p resolution and native 16:9 aspect ratio
* 3-LCD Epson technology
* Maximum 1000:1 contrast ratio
* Up to 1300 ANSI lumens
* Includes Epson ColorReality?, a high-precision color and image reproduction system
* Wide range vertical and horizontal lens shift
* Five preset color modes
* Fine tuning of individual color levels (RGB)
* Remarkable video processing
* No light leakage body design
* Easy to install, plus complete control over your cinema experience
* Renowned Epson service and support
Specifications
Projection System
* Epson original LCD prism technology
Projection Method
* Front / rear / ceiling mount
LCD
* Size: 0.7" wide
* Driving method: Poly-silicon TFT Active Matrix
* Pixel number: 1280 x 720 pixels
* Native resolution: 720p
* Aspect ratio: 16:9
* Pixel arrangement: Stripe
* Refresh rate: 50Hz or 60Hz (based on input signal)
Projection Lens
* Type: Powered zoom / focus
* F-number: 2.1 ? 2.8,
* Focal length: 21.4 ? 31.7mm
* Zoom ratio: 1 ? 1.5
Lamp
* 200W UHE
* Lamp Life: 3000H¹ (Color Mode: Theater Black / Theater / Natural / s-RGB), 1700H¹ (Color Mode: Living Room / Dynamic)
Optical System
* Dichroic Mirror Separation and Prism Combine Method
Screen Size (Projected Distance) - 16:9 Image
* Wide: 30" to 300" (2.9' ? 29.9')
* Tele: 30" to 300" (4.4' ? 44.8')
Lens Shift Range
* Vertical: 100% max (upward), 50% max (downward)
* Horizontal: 50% max (left and right)
Brightness
* Up to 1300 ANSI lm (Color mode: Living Room / Dynamic)
Contrast Ratio
* Up to 1000:1 (Color Mode: Theater Black)
Brightness Uniformity (Typical)
* 90%
Effective Scanning Frequency Range (Analog)
* Pixel clock: 13.5MHz to 10MHz
* Horizontal: 15KHz to 92KHz
* Vertical: 50Hz to 85Hz
Adjustment Function
* Tilt angle: 0° to 3.6°
* Keystone correction: Vertical: ± 15°,
* Cinema filter: Controlled automatically with color mode (ON: Theater / Natural / s-RGB, OFF: Living Room / Dynamic)
Video I/O
* Component Input
Input signal
o Video standard: 480i / 575i / 480p / 575p / 720p / 1080i
o Video signal: Component Video (Analog Y level 0.7V 75 ohm / Cr Cb level ±0.35V 75 ohm / sync.negative 0.3V or 3-state± 0.3V on Y)
o Input
+ RCA x 3 (Red / Green / Blue)
+ D4 video (only for Japan)
* Composite / S-Input
Input signal
o Video standard: NTSC / NTSC4.43 / PAL / M-PAL / N-PAL / PAL60 / SECAM
o Video signal: Composite Video (1.0Vpp / sync.negative, 75ohm) / S-Video (Luminous 0.714Vpp, Chrominous 0.286Vpp, 75 ohm)
o Input
+ S-Video: Mini DIN 4pin
+ Video: RCA (Yellow) x 1
RGB
* Analog RGB I/O
Display performance
o Native: 720p
o Resize: 1280 x 1024 / 1024 x 768 / 800 x 600 / 640 x 480 / 480i / 575i / 480p / 575p / 720p / 1080i
* Input signal
o Signal type: Separate Signal
o Video signal: Analog (0.7V p-p,75 ohm / Mac0.714Vp-p,75ohm)
o Sync. signal: Separate (positive and negative, bi-polarity 2-5Vpp) Composite (positive and negative,bi-polarity 2-5Vpp) / Sync-on-green (negative,0.3Vpp)
* Input
o Video: Mini D-sub 15pin x 1 Blue-molding
Control I/O
* Serial I/O
o I/O terminal: Mini D-sub 9 pin x 1 USB-type B
o I/O signal: RS-232c
Lock Function
* Key-lock, Child-lock, Focus-lock, Zoom-lock
Operating Temperature
* 41°F to 95°F (5°C to 35°C)
* Cool-down period: Approx. 30 seconds
* Start-up period: Approx. 15 seconds
Power Supply Voltage
* 100-240 VAC ±10%, 50/60Hz
Power Consumption
* 100V area
o Lamp ON: 270W (Lamp high), 210W (lamp low)
o Standby: 0.3W
* 120V area
o Standby: 0.3W
* 230V area
o Lamp ON: 260W (Lamp high), 200W (lamp low)Standby: 0.5W
* Except Japan: 100 - 240VAC 50/60Hz 3.0 - 1.4A
Dimensions
* 12.6"D x 17.3"W x 5.3"H (excludes lens and feet)
Weight
* Approx. 11.8 lb / 5.3kg
Fan Noise
* Normal mode (Dynamic / Living Room): 36dB
* Quiet mode (Theater Black / Theater / s-RGB): 28dB
Warranty
* Two-year parts and labor limited warranty, 90-day lamp warranty, Epson HomeService Program and Epson PrivateLine dedicated toll-free support (U.S. and Canada only)
Accessories in the Box
* Power cord: 3m, Remote control: Stick type, Battery: AA x 2, USB cable: 1.8m, Epson cinema color editor CD, User's manual, Warranty instructions, PrivateLine card / PrivateLine card holder
Notes
* ¹Lamp life results will vary depending upon mode selected, environmental conditions, and usage.
ONLY bad thing I can find may be the inputs on the back. NO HDMI.
Make a great theater PJ for your sports bar if you power it with a pc or laptop. Or even just for your 360/PS3, it would look fabtabulous!
Screens can be had at a decent price at Tiger Direct, or buy the fabric and make your own screen buying the material on ebay
Status
