Powering 2 - 30" LCD with GeForce 7950 GX2
jay35
Can a single GeForce 7950 GX2 power 2 - 30" LCD to the full native resoultion or do i have to buy 2 of these cards
Jay
BassBomb
8,390
Jay
Hikari is right, and anyways you cannot run in Sli with dual monitors.
krotchy
1,942
The 7900GT,7900GTX, 7950GX2 and 7950GT all have 2xDual Link DVI. So all four will run 2 30 Inches fine. However, unless your going to be gaming a ton, you would be better off with either GT or GTX than the GX2. Not to mention, when using 2 monitors I am pretty sure you can't turn on the 2nd core of the GX2. This would mean your be stuck with essentially a super expensive 7950GT. Of the four cards I mentioned, and since you already were willing to spend money for a GX2, I would go with a 7900GTX as it is the quietest of the bunch.
8 Megapixels of desktop space is kinda scary though, but in a good way.
jay35
Thanks for this info, I thought since it had 2 GPU it can power both monitors
Is my other option is to buy 2 cards if I want bother moniters powered at full speed
Jay
