PowerColor Radeon 9600 (low profile) - help compare to my current card please.
Cheetah8799
4,508
ok, I know most of you guys don't like Low Profile cards. But I value the space it saves me, so I stick with it. The problem for me though is that I like to play games too, and am looking forward to HL2 (if it ever gets released...).
To get to the point... PowerColor has started selling the Radeon 9600 low-profile card here in the US. NewEgg just started carrying it, finally! I currently am using a PowerColor Radeon 9100 (which nobody sells anymore, and I don't know the specs for). I know the 9100 is a little better than the 9200se from what I've read. I want to know how much better the 9600 will be than the 9100, if at all. Sadly I am not a video hardware expert, so I am coming here for help.
NewEgg Product Link
PowerColor product link
Specs from newegg for 9600
POWERCOLOR ATI Radeon9600 Low Profile Model R96LE-C3 - RETAIL
Specifications:
Chipset: ATI RADEON 9600
Memory: 128 MB DDR
Bus: AGP 8X (Low Profile)
Core Speed: 325
Memory Speed: 200 x2
PowerColor's site includes some more info:
"optimized architecture" for DirectX 9
Specs for PowerColor 9100 low-profile (my current card)
Sorry I don't have much info here...
Radeon 9100 chipset
AGP 4x
64mb DDR
Thanks for any help and insight anybody can provide.
-Josh
TheAudit
4,194
It should be loads better, a noticeable difference.
Just how much better exactly? Well, they used to compare the 9100 to the MX 440 (they were about the same). The 9600 is a big step up from the MX series.
Jan 31, 2002
40,819
9100 = DX8
9600 = DX9
How about "Utter frickin craploads different?" In nVidia terms, you're graduating from "geForce3 Ti200" to "geForce FX 5600"
- M4H
Quixfire
6,892
Also the 9100 is a warmed over 8500 with clock speeds around 275/400 and the 9600 non-pro are, as you stated, 325/400.
Blastman
1,758
Assuming your Powercolor 9100 64MB is not a low profile card with 64bit memory bus. Its performance would be about the same as a 9600. They both will score in the ~ 9000 range in 3Dmark2001 on a fast system.
That low profile Powercolor 9600 is on a 64bit memory bus which usually means about a 30% performance hit over the normal 128bit 9600?s --- which means it?s probably 30% slower than your 9100.
You would have top go to a 9600pro if you want a jump in performance.
Blastman
1,758
A few 3DMark2001 scores from around the web ?
9600 128MB 325/200 ? ? ?9104 ? (Athlon XP 2600+)
9100 128MB 250/200 ? ? ? 8760 ? (P4 2.48 -- 550fsb)
9100 64MB 250/230 ? ? ? 8894 ? (P4 2.4 -- 533fsb)
A 64bit 9600 is going to take a big performance hit over that 9600.
Blastman
1,758
Since a 9100 is about as fast as a 9600 (9100 is probably a little slower overall). Your 64bit 9100 should be about as fast as the 64bit 9600 your thinking of upgrading to.
Conclusion:
You might see a small increase in performance but it would be marginal. Not worth spending money on this upgrade at all IMHO.
Better to go for a full sized card 9600/9600pro.
Cheetah8799
4,508
The mfgr says they are 64bit.
EDIT: actually finding where I read that is proving to be harder than expected... I think it's kinda common knowledge that they can only do 64bit on the low profile cards.
EDIT2: The powercolor page says this: " Four parallel rendering pipelines process up to 1.6 billion pixels per second 128-bit full floating point precision enables billions of color variations to render the same lighting and effects as Hollywood studios"
Maybe the 9600 really is 128bit??...
Blastman
1,758
powercolor?
Model
Chipset
- RADEON 9600
Support Memory/bandwidth
- 128MB DDR SDRAM
- 64 bit
Connectors
- VGA
- TV-out (Composite connector)
- DVI Connector
Blastman
1,758
Newegg lists the Powercolor 9600 128MB low-profile (64bit) at ?$122
[*]You can get a regular 9600 for the same cost that is 30% faster.
For only $30 more you can get a 9600 pro ? either ?
Transcend ATI Radeon 9600 PRO 128MB ? $152
CONNECT3D ATI RADEON 9600 PRO 128MB DDR ?$151
[*]These pro?s are 30% faster than the regular 9600 cards.
[*] pro is a huge upgrade (60% faster) than what you?re looking at.
