94 Mazda B4000 V6 4.0L, promise this is my last post
Driver side power window does not work. Passenger side still works, even using driver's side button. Fuse has a metal case so I can't see if it is blown, but the two windows share the same fuse so I assume that is not the problem. Power locks on driver's side still work.
This seems to mean I definitely have to open up the door, and likely replace the lift motor. Just thought I'd run it by you guys first since I've never dealt with this before. I have a good set of instructions for performing the replacement.
