Power washer won't build pressure?
Quixfire
6,892
Hello to All,
I have a Craftsman power washer that won't build pressure, it just let's the source pressure through the systems. I have replaced all the check valves in the valve body and cleaned the pressure valve and it still doesn't work.
Any other suggestions or ideas?
Thank you
Stifko
4,799
Does it have a wand? Maybe the sprayer needs work? Isn't that where a lot of the pressure is built up?
Ulfwald
Moderator Emeritus<br>Elite Member
May 27, 2000
8,646
Check the wand, sometimes the tip is set to low power. try it in many different positions
Quixfire
6,892
It's not the wand, I have cleaned it and the water does come out but at the same rate it goes in.
