I just braught my computer back from a lan party which worked fine there. I had the voltage switched to 220 (i live in europe) and plugged into 220 obviously. Then i went back home and switched it back to 110v and plugged it into my transformer, and to my surprise, when i turned it on, the fans spun for a split second and then turned off. Even the PSU fans spin for a split second. I then immediately searched the web for a solution, and followed their procedures. I unplugged everything but the essentials, and still nothing works. I have tried different outlets, and made sure nothing was touching the motherboard. Rember, the computer was working perfectly fine at the lan party.
My computer's specs are as follows:
Asus A8V Mobo Bios 1006 rev 1.02
130nm Amd Athlon 64 3500+ Processor
2x 512 mushkin value ram pc3200
2x WD 200gb Harddrives
DVD Burner
XFX Geforce 5900xt 128mb
Thermaltake Silent Pure Power 420watt PSU (worked fine b4)
Please help me find a solution to this, it is very frustrating not being able to use my expensive toy. Thankyou very much!
DVD Burner
