Power up Motherboard ON
Sharkmeat
467
When I pug in the power cord into my power supply to start up my P4PE MotherBoard,it turns on and run for about 5 seconds and shuts down.
Then I push the power button and it come on normualy and runs fine.Is this a glitch for these Motherboards ??.I took the MB out of the case and ran it with just the video card for a test and when I plug the power cord into the power supply the same thing happen,it started the fan on the cpu and green light came on with out haven to hit the power switch or jump it with a screw driver on the power pins.And on top of this it run at a high 41 C at idle.I no the cpu is good (2.4-B-ver) because I ran it fine with my 533-C and the temp ran at 31 C.
Maybe my Motherboard has a voltage regulator problem!!,whats your thinking on this problem.
Asus helps is as good as ever on there information.They make a great Mboards and great RMA support,but lack answering a problem question through Techsupport.Any iders you may have will be appreciated.Thx,s in advance.
BTW if you get confused at this post I will understand I,m no grammer king.
Peter D
3,603
i have no idea really, except for maybe the cpu fan rpm is not being sensed by the motherboard, and its shutting itself off to protect the cpu.. that happened to me once.. sorry im of no more help.. :confused:
KGB
3,042
Regarding the 5 sec. power ON condition, this normal operation so do not worry.
Sharkmeat
467
Thanks KGBMAN / Vegetto for your replys the board runs fine and the high temp reading seem fishy because the heat sink in not eveb warn to the touch,I have smart fan enbled and the fan says on low speed even through it read 41 C wired!!.
