Power Tools Suggestions?
Anubis
78,712
427
tbqhwy.com
I use Bosch and DeWalt, the GC who has rebuilt most of my house uses DeWalt
never had an issue with either
love my Bosch Router
Greenman
20,893
5,524
I like Bosch but thats mostly because Amazon has frequent sales on big kits.
Cant think of a reason to recommend them over any other brand. All my Bosch tools have seen plenty of use and came up shining.
We had a bunch of stuff to do at the gun range. My power driver got used all day and the battery never died.
http://www.amazon.com/Bosch-CLPK27-1...dp/B0046ZRYPE/
Bosch is another solid performer, you really can't go wrong with them. I just picked up their top of the line jigsaw and it's a very nice tool.
Carson Dyle
8,173
524
I bought that same Bosch 12V kit several years ago and absolutely love it. I'm not sure I'd use the impact driver to build a large deck or an addition to a house, but for just about any other job, it's more than up for the task.
slashbinslashbash
1,945
8
Funny. In 2007 I bought a used Black & Decker 18V set from a pawn shop for $100. It has a small circular saw (5" or so?), a cool drill/driver where the chuck part comes off and reveals a hex socket underneath, so you can keep a driver and a drill bit on the same tool and switch between them just by pulling off the chuck part; a reciprocating saw; and 2 batteries. Those original batteries are long since worthless, but the tools are still going strong (I found some drill/drivers at Walmart on clearance for $35 each a few years ago that use the same batteries). I now have a corded circular saw, a table saw, and a compound miter saw, so the little circular saw doesn't see much use; and I haven't really needed the reciprocating saw since I demo'd the wall in my condo; but the drill/driver is still my main piece. Yes, it's heavy and bulky with the old NiCd batteries. But it's got a nice gearbox and easy torque settings.
Of course, I'm just a simple homeowner. I don't rely on these tools to make a living. But those tools have seen me through 8 years of minor household projects. Yes, they are orange-and-black junk from China/Walmart, but they have been sufficient for my needs, and they have never let me down aside from battery issues (even so, a fully-charged battery will still last a full day of moderate use in the drill/driver). I wouldn't hesitate to buy a similar $100 used set from a pawnshop again, given the ability to test each piece for functionality.
