I have just set up my rig w/ the DFI Ultra-D motherboard. When I pushed the power button, nothing happened. But it fired right up when I pushed the onboard power switch. One thing that I found out is that there are 3 pins on the board while the power switch connector of my case has only 2 pins. I have tried all the possible combinations, but no luck. I know my power switch works because it worked on my MSI Neo2. I'm just wondering if this is a compatible issue or I just got a bad board. If the board is defective, I'll just RMA it. I doubt that the 2 pin connector doesn't work with the board. However, if this is really the case, what can I do to make this work? Thanks!
