Power surge issues after shutdown
DrDon
8
have a Shuttle AK31 v3.1 motherboard. As of lately I have been having
some power surge issues or something of the sort. Meaning, when I do a
shutdown from Windows XP or a manual shutdown by pushing the power button on
the front of my case I still hear the fans pulsing at very low speeds and
lights are flashing (on motherboard, on front of case, on video card, etc).
The only way to stop the "pulsating" is to turn the power supply off
manually from behind. Now, I assumed this was a power supply issue and
others agreed with me on these boards so I went out and bought a brand new
Thermaltake Purepower 420 and installed it today. Well, the same thing
keeps happening. So, one by one I uninstalled every piece of harwdare I
could think of and powered up the CPU after each hardware removal (RAM,
video card, net cards, sound card, etc) and the exact same thing occurs
When the power is techincally turned off, the system still "pulsates" with
the low RPM on the fans and the lights flashing and making a noise with each
pulsation. Thoughts? Suggestions?
Can this be some kind of sleep mode that somehow got enabled in the
BIOS? Is this a motherboard issue? I just put in a Nvidia 6800 a few days
ago and if it somehow gets fried I'm going to be very very unhappy (Yes, the
issue started way before I put in the new video card). Any help would be
greatly appreciated!!
HermDogg
1,384
Were you on the same outlet the whole time? Maybe try a different one? You're right, it does sound like a surge issue... Are you on a surge protector (not sure if its the cause/solution, just wondering)? But the system does it even when stripped down to BASIC (mobo, CPU)?
stevennoland
423
Your mobo could be going bad. It is responsible for shutting the power supply off. Check this first.
