Setup :
Cable modem, two computers that are not networked due to a down router, both XP.
Power surge the other night, definitely killed my network router (along with some TVs and a garage door opener).
Problem :
I currently can only get internet if the cable modem is hooked into the integrated network port on one of my computers (call it Computer A). If I plug it into Computer B's integrated network port, I get the error "network cable unplugged". I know what you're thinking....fried network card. But I added a PCI network card and it still won't come up. Ok, bad motherboard on Computer B. But, if I take that network PCI card and plug it into Computer A, it won't work on Computer A (although the integrated network port on Comp A works fine). Ok, bad network PCI card. Bought a new one, different brand....same thing. Called cable modem company, they reset the modem on their end and I power cycled it on mine. Same thing. Changed all the network patch cables, no help. I am not even getting any link lights connecting the cable modem to these network ports except for the integrated port on Computer A.
So the cable modem only works on *one* port on *one* computer. I've tried every kind of combo I can think of and it won't work. The network card installs fine in XP. I've tested the PCI slots with firewire cards and they seem to be okay. What on earth can be wrong?
Problem :
