Power Supply
Vicious38
47
My Rig - Ultimate Gaming System
That will be my Gaming System. My Power Supply will be a PC Power and Cooling 510W ATX-Deluxe. Will this PSU support my system? Do I need another PSU? Do I need a different one? Is there even a better one? Should I remove some certain "Features" from my computer? I don't want 4000 Dollars going down the drain, because of one 200 Dollar PSU...
Porter21
1,912
It should work without any problems. 5120w should supply pretty much anything with enough power. I am currently using a 350w ps and it has had enough power for everthing in my case. You could try higher wattage ps, but you should be fine wiith what you have.
stevty2889
7,036
8
That PSU will work fine with your system. PC Power and Cooling make some of the best PSU's available.
Mik3y
Banned
Mar 2, 2004
7,089
its far more then enough. if anyhting, its overkill. :)
a quality 300W psu can handle it also.
