Power Supply
steell
1,569
Or you could just buy a PSU tester, I think Newegg sells them for around $15.
ScrapSilicon
13,625
Originally posted by: CheapArse
oh...
if i plug it into an outlet, that wont hurt anything correct?
not sure hence the ? and :confused: smiley..I usually have a spare mobo around either a non-booter just to be able to test a psu...no proc, no anything...just to make sure the mobo connector does its loop..
snidy1
1,285
oh...
Yes it will, If you don't have anything drowing power from it you'll probably fry it
emjem
1,516
oh...
Sorry, that's not correct.
First unplug the power supply from its 110 volt supply. Then unplug the power supply from the mobo, hard drives, floppy and everything else it's connected to.
Then plug power supply back into 110 volt supply.
Next, use a wire, paper clip, or whatever you feel safe with, to jump from a black wire hole to a green wire hole on the connector to start the ps up. If the ps fan doesn't run with this jump you have your first clue. Then you can plug a known good fan to one of the power supply cables/connectors to see if there is no power or if it's just that the ps fan is bad.
This is just a quick simple easy tests to give you a clue. If fans won't run the probablility is high that the ps is bad. Conversely you can have a fan running but still have a bad power supply.
