power supply won't fit in case power hole
imported_darin
Hi,
Guys i just bought a power supply and case but the power supply won't fit in the case.
Both are ATX so should work but does not I have a Thermaltake Armor VA8000SWA Silver Aluminum with a seasonic S12 600w ATX 12V v2.0.
I called 800 phone for Thermaltake and they said it should fit in case if is ATX.
Sir, that power supply has fit in the Armor perfectly fine. Please attempt
to reinstall the unit.
If you have any further questions, please feel free to reply to this e-mail
or contact or technical support department toll free at (800) 988-1088. Our
technical team is open Monday through Friday, 9:00AM to 5:30PM PST. "
but it won't go in Demensions are off.
The power hole on the back of the case is not big enought for power supply to fit in on it's
side. It will not standup hits the top of case before it will stand on it's side like it should.
seasonic S12 600w ATX 12V v2.0. Demensions are lenght 5.9 width 5.5 hieght 3.4
is this with in standard ATX power supply size or is it slightly over sized ?
case info
http://www.thermaltakeusa.com/product/Chassis/fulltower/armor/va8000bns.asp
or
http://www.newegg.com/Product/Product.asp?Item=N82E16811133155
power hole on back
http://img240.imageshack.us/my.php?image=atxcase4ns.jpg
Any one here had problems like this.
Thanks,
Darin
I have the same case and I have a Ultra 550 modular psu in it..its deminsions are...5.9x3.4x6.25 if the web site ..Xoxide.com I found the demisions on are correct. had no problem gettin it in there... hope ya get it goin.. the Thermaltake Armor case is great imo.. keeps good temps. uhh not tryin to make ya sound slow or nothing.. but ya are tryin to put it in from the inside and not the rear?
Thermaltake Armor VA8000 case
AMD Athlon 64 4000+
Gigabyte K8N-Pro-SLI
OCZ Platinum Dual Channel 4x1024mb(2-3-2-5)
WD 250 gb SATA2 @7200rpm
Ultra X2 modular 550 watt psu
2 x EVGA 256mb Nvidia 7800 GT (470 core- 1.1 ghz mem)
19? Samsung 930B @1280x1024
Sound Blaster Audigy 2ZS
Creative 2.1 80 watt (semi-surround)..lol
HP Lightscribe
Logitech G7 Laser cordless mouse
Saitek Eclipse keyboard
