Power supply woes
Rinaun
When sleeving my PSU, i have to take off the molex on my 4 pin molexs'. Does it matter which order the blacks are in? theres the two blacks in the middle and i need to know if I need to remember which black goes in which hole. I would guess it wouldnt matter since theyre both ground. Any tips would be appreciated.
-Rinaun
Hi, Galvan is correct. I think I would look for spiral sleeving. It can be applied without removing the connectors. I don't know if it is still available. Haven't seen any in many years. Still have some in the junk box. Jim
Spiral and split sleeving is easily had in black. If I were young and wanted bling spiral
sleeving, I'd head to Pep-Boys for the loud colors offered there.
OP, if you go for chromed spiral make sure it's plating is non-conductive with your ohm meter.
...Galvanized
