so i decided to go all out and get a v2000 lian li case. its gonna be a huge fing case i know... and my main problem is that i'm more than likely going to go with a DFI board in it that requires a 480 watt power supply w/ 24 pin connector native. i know that PCP&C and Seasonic is good but are the cables included long enough for a 2 foot high, 2 foot deep case?!?! I also don't want to spend alot if i don't have to so PCP&C is out. (just to remind you all, the cables need to be longer than 24" in most cases cause the cables will probably be at different angles... ect.). My current choice is this psu from OCZ cause it has 28a over the 12v line which is good in the future for the 7800gtx as opposed to seasonic's 18a or so over the 12v line:
http://www.newegg.com/Product/Product.asp?item=N82E16817104152
Anyone know if the cables will be long enough for the case i'm putting it in? If not is seasonic's cables long enough?
BTW case pics and specs can be found here:
http://www.newegg.com/Product/Product.asp?item=N82E16811112053
thanks.
thanks.
