Power Supply Voltage Ranges?
JamesInLV
Hi,
My system works fine, but before I put in these two brand new hard drives I just picked up, I thought I would concern myself with my PSU. I have an Antec 300w supply, about 3 years old now. A couple months ago my Asus mobo monitor popped up warning me that my +12V had jumped past 13v. It reports 13.248v right now. My +5, +3.3 and Vcore all seem to be inline. I pulled up SiSoftware Sandra and here is the information from there:
CPU Core: 1.66v
Aux Voltage: 2.50v
+3.3V: 3.39v
+5V: 4.97v
+12V: 12.71v
-12V: -11.69v
-5V: -5.21v
Asus PC Probe readings:
+12V: 13.376v (don't know why the major difference in readings)
+5V: 5.053v
+3.3V: 3.392v
Vcore: 1.664v
I don't know why the readings are so far apart on the +12V. Are at least the Sandra readings within tolerances, or is that +12V just too high? My computer is VERY stable, never having any strange problems with hardware or software, though it has been running a little hotter lately than before this problem came up (typically was in the 90's F mobo and CPU where now it runs low 100's F mobo/CPU unless I'm playing games.
Thanks!
Software temp monitoring is not very accurate. If you really want to know what's going on measure a molex with a multimeter while your system is under load.
Thanks for the tip! Couldn't find any spot to pick up a +12V reading, but got these off a molex...
5.06V
-12.40V
Also found a -7.4V reading but I guess that's a completely useless measurement.
Everything okay here? I guess the -12.40V is helping me not worry as much anymore.
Those voltages look fine. Can't you get the +12V off the yellow wire in the molex? You would put the red lead from the DMM in the yellow wire and the black in the black.
Yeah...I was just working the wrong way across the molex. red->yellow, black->black I get +12.40v, so that 12.4v reading I gave before was just with the red/black connections on my meter the wrong way. Glad to hear that part is okay.
So one stupidity item on my part...here I am thinking I had an Antec supply in there, though it is an Antec case... turns out to be a Deer Computer Co. supply. I'm running a P-III, 733mhz, a couple hard drives, TI4200 video, two sound cards, cd-rw, NIC, SCSI adapter (one of my current drives is a SCSI). When I upgrade the mobo/CPU I'll get a new case/supply anyway. Sounds like I'm safe with these voltage readings, and the supply has never presented a problem in any other way.
