xorifrafox
I have an ANTEC case and power supply on 2 of my 4 PCs running in my home network. All my PCs are AMD based with ASUS Mobos. One of the last machines that I built was made from parts and pieces of discarded or older hardware. The case was generic and the power supply was only a 250 watt model. As soon as I powered it up, the ASUS +12 V monitor kicked in and showed a constant voltage of about 13.53 volts. My other machines, with the ANTECs, run around 11.5 to 11.77 volts and NEVER exceed 12V. Within a week of getting that last machine running the power supply went belly up. I purchased an off the wall brand case off of eBay with a 420 Watt Power supply, put the machine back together, and as soon as I powered it up the +12 volt monitor alarm was back and showing + 13.5 volts. Am I just using crappy power supplies on this machine and am I heading for another failure, or is there something I'm missing here? Suggestions??
