- Sep 14, 2004
- 759
- 0
- 0
Ok, first here's the setup:
Windows vista 64 bit
4 gigs mem super talent ddr 2 667
athlon 64 x2 3600+
Biostar TA690g motherboard
xfx 8800gts 320 mb factory overclocked edition
2x sata hard drives, dvd drive.
Antec NeoHE 550 Watt psu*
*(keep reading)
So this PC was built, booted up and installed windows just fine. Started doing some stress testing with various games, ut2k4, rainbow six vegas, and some dvd playing. About five to ten minutes in to play, the computer will show a black screen for 5 or so seconds, then it will either recover and continue playing the game or whatever, or it will stay black indefinitely, requiring a reboot to fix it. I figured it was a power problem. On paper, the NeoHE should easily be substantial enough to power the system, so I figured there was something wrong with this particular one. Bought a new one from Worst Buy (TM), had the same problems. Took that one back, bought a BFG 650 Watt power supply. Same problem. I think it's a power problem because I can reproduce it by playing back a large demo and doing lots of hard drive reads and writes at the same time, but these power supplies should be more than ample to power the system. The hard drive reads and writes seem to make the black screens much more frequent.
Ran memtest and prime95 to make sure it wasn't a cpu or memory problem. Those ran flawlessly.
So my question is, do any of you have any insight? I thought it might have something to do with split rails, but I tried a bunch of different rail configurations and got the same problem. The pc doesn't have this problem when using the integrated graphics on the motherboard.
Should I buy a newer, even bigger, power supply to run this system, or should I look for another culprit like the motherboard? Help me out here. Let me know if you need any more info.
athlon 64 x2 3600+
*(keep reading)
