Power supply Thermaltake W0116RU
loco21
ECS P965T-A (V1.0) Socket T (LGA 775) Intel P965
Thermaltake W0116RU 750W Power (may be)
1 Intel Core 2 Duo E6700 Conroe 2.66GHz LGA 775
2 G.SKILL 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
1 Seagate Barracuda 7200.9 ST3400633AS 400GB 7200 RPM SATA
1Western Digital Raptor X WD1500AHFD
1 eVGA 01G-P2-N592-AX Geforce 7950GX2 1GB
plus 2 printer on usb
I have everthing but no PS yet
2 dvd burnner IDE
I'm going to get a ps and I was wondering if this it is a good power supply here is the link:
Thermaltake W0116RU
thanks in advance !!
Originally posted by: GalvanizedYankee
This says 400W ought to do'er http://www.extreme.outervision.com/psucalculastor.jsp
One PSU I'd really consider...Corsair 520W, reviewed at http://www.jonnyguru.com/
I bought an ECS board for my Sister's build. The capacitors on ECS boards are NOT of the
best quality. Expect stabilty issues in 2~3 years if the board is worked hard.
...Galvanized
well thanks again but I don't know why but it show to me that I need a 618 w I just add that I have 1 92mm, and 1 120mm lead and 120 mm regular and some hhow it tell me that I need 618 oh well any way I got me the 620 corsair that will be plenty
Originally posted by: acegazda
which boards use the best caps?
Generally...TYAN and SuperMicro.
A board you see in a review maybe populated with lesser caps than shown in the review.
Stocks do run low and suppliers are switched to keep production going.
If it really concerns you, buy your boards at a B&M. Open the box and see what's there
before making the purchase. High end boards generally have what is on the reviewed board.
Read some of the mainboard forums over at http://www.badcaps.net/ You'll have to
register to view attachments.
...Galvanized
