Those are fine, as long as your comp isn't restarting or shutting off for no reason you shouldn't need to upgrade unless you plan on dropping a Geforce 6800 ultra any time soon.🙂
I wouldn't worry about any of that unless your computer exhibits stability problems. As long as it is operating fine, then all the better. Less voltage = less heat. Therefore, the CPU should last longer than one at standard voltage, in theory.
