- Oct 3, 2006
- 1,971
- 0
- 0
This is not a new problem, but it seems to be getting worse over time. If I unplug the power supply from the outlet, it takes several minutes before it will start up. It will often start momentarily and cutoff several times before staying on. Vaguely recalling some discussions about this sort of thing here on the forum, I remember something about a PS having to see a minimum amount of load, or it will act this way. There is no problem if I simply shutdown with the power switch, or restart. The question is, if there is a way that I can rig it so that it sees this load, or if I have to RMA it. Considering the problems that I had getting an Antec that worked at all, I'm not too anxious to roll the dice again with Antec unless I have to. Any suggestions?
