Power Supply Sleeving?
sep
I attempting to sleeve my Antec True Blue 480 and don't know how to get around the Serial Hard Drive connectors. It doesn't come off line the other molex ends. Anyone got ideas?
It looks like I'll just have to use small color coded ties to put at the end because I can't get the heatshrink over the Serial Power End...bummer!
Disasemble the serial ata conector and reaseble it after you put the heatshrink in.
Be very careful as those wires are thin and can break easily.
Mine are sealed all the way around. I'd have to brake them and don't want to do that in fear of not getting them back together.
What about Rubber Bands? I'd need one at least 1 to 1 1/2 inch think, black and strechable to go around the serial ends and collapse back down to...1/4 for smaller?
Ahhh!
SVC used to sell sleeving that just wrapped aroud the cable and closed somehow. If not get sleeving a little bit bigger than you need and use it,most of it stretched a lot.
