Power Supply size?
MGF Derp
25
There is ATX Micro ATX and a few other standards for power supplys. Most common is AT which is what your Antec 630W most likely is. The HP might use a Micro ATX if it is smaller then your Antec but without a power supply model number or at least a picture I couldnt tell you for sure.
Zap
22,377
7
It looks ATX sized, but with a slightly different bolt pattern.
fralexandr
2,289
229
www.flickr.com
the dimensions on the HP power supply are normal, your antec is probably the longer 160mm (in comparison to the 140mm used in the HP) type
Dimensions: 150mm x 140mm x 86mm (5.9 x 5.5 x 3.4 inches)
the HPs PSU dimensions match up with stuff like this corsair cx500 v2 (the size used by most PSUs under ~600W)
http://www.newegg.com/Product/Produc...82E16817139027
this should be good for almost any single GPU solution
