After i install the drivers for my leadtek fx 5900, after re boot it hangs like after 5 seconds in windows xp, i tryed updating the latest driver from nvidia and it still doesnt fix the problem, i had some problems earlier on and it was telling me about something to do with the fx 5900 not recieving enough power, this was fixed by me plugging a power cord from the power supply into the card which had previously been left out. now it no longer has a power problem but xp states that "the fx 5900 display driver is causing system instability"
i read on a few sites that they said there is a minimum 450W power supply required for it and i read somewere else there is a minimum of 350W power supply, i currantly have a 400W.
Can anyone help me and tell me what is the cause for this? i have installed all the updated drivers and even tryed rolling back to the driver supplyed with the card.
thanks, alex
my pc specs are:
p4 3.0ghz C
GA-8S48FX
512 DDR 400
Leadtek fx 5900
80gb ata133 hdd
thanks, alex
my pc specs are:
p4 3.0ghz C
GA-8S48FX
512 DDR 400
Leadtek fx 5900
80gb ata133 hdd
