Power supply recommendation
ShallowHal
456
I went to AMD's website for power supply info but I couldn't find it.
Any recommendations for power supply. I have an xp1700 and the case I'm using has a 300w ps by Codegen. From what I read that may be inadequate.
I'm trying to solve a very vexing problem on my new system and the power supply is one of the two options I have left.
Sorgon2
420
There are 2 new Enermax PSUs on the market now:
Enermax 350W ATX Speed Dial
Enermax 431W ATX Speed Dial
Enermax is a trusted brand IMHO and I am using one on a T-bird 1.4 now with no issues. The "Speed Dial" option is pretty cool, though I don't own one. It allows you to control the fan speed via a dial on the back of the unit and this of course helps with noise. Good Luck!
Grendel99
888
Also might wanna look at the Antec 400 watt. Very good powersupply. Check out the AMD website for recommend PS's.
