power supply recommendation?
I'm running for northwood p4 2.4 ghz
1 gig of corsair
2 hd's 160 gig and 120 gig
and 2 cd rom drives
and a nvidia gforce 4 ti4200
what do u guys recommend for a power supply? and at what is the minimum wattage i should go for? i want to get something that is well above my specs just so that if i get a new computer in a couple of years i don't really need to change the psu.
thanks!
i'm not really concerned about price..more concerned about quality..but i don't want to overspend if i don't need to...so anything from 80-120 should be okay
Don't even consider a Thermaltake PSU. They tend to droop their rails under load. That OCZ is a great PSU though :thumbsup:
I don't think so. I don't see so either. I've had a few dozen of their PSUs and none of them drop.
I'd say you you should go with an Antec or a Seasonic PSU.
Yes, the Antec Truepower lines are great, or if you want to save some money, Superflower makes fine PSUs and they're selling at a very reasonable cost.
oh man just did some more research...looks like the ocz is longer tha normal power supplies? i called ocz and they said by an inch or 2...that's humongous
it might not even fit in my case =(
Wow, look at these guys.
Whoever is reccomending a PSU that puts out more then 350watts is a moron.
I suggest somthing close to 350 watts.
Good brands include,
Forton
Sparkle
Seasonic
Enermax
Antec
Stay away from OCZ, they are pricey and usualy for high end systems.
You dont need 400 watts.
I could run that system with a 250 watt antec.
My old P4/GF4 system ran stable on a 200 watt psu.
Forton
Sparkle
Seasonic
Enermax
Antec
Did you actually read his first post? 😕
He wants it to be able to run a new system in a couple of years also. PSU's are one item that future proofing makes sense. Don't be so quick to criticize others dude.
Forton
Sparkle
Seasonic
Enermax
Antec
Couple of years.....
LoL
He wants to use the same PSU 3 years later?
Good luck with that.
Future proofing a psu for that long is foolish.
He is better off getting something cheap for around 30 bucks that will run his system fine now until he wants to upgrade.
If I had the same additude 3 years ago, I would be stuck with a 20 pin psu and 24 pin motherboard.
