haven't really kept up to date on hardware for the past two years, so would appreciate any recommendation.
my coolmax 400w el cheap $40 PSU is starting to fail. funny that when I checked the newegg order history & product review, others unit has failed already (or starting to).
due to its crappy 12 rail, i was never able to clock this mobile athlon 2600 any higher than 2.3 ghz stable. been researching a bit but it seems old sure bets such as antec aren't exactly sure bets anymore.
I can probably just slap in a fortron 400w and call it a day? but I was thinking a stable 400-500w w/ good 12v might be a good bet, since this machine will be good for a home theater system (good old soundstorm).. and I'm fairly certain the athlon 2600+ can hit 2.4 ghz (since it did w/ a better PSU I borrowed from friend).
needs the PSU to be fairly quiet. going into a fairly silent rig.
price range: $50-$100 ?
there's a thermaltake TR2 500w at newegg for 54 after $20 rebate.. but it seems there are better PSU manufactures out there.. enhance, fortron, seasonic etc.?
again, appreciate any suggestion or input.
it seems the seasonic s12-380 or 430 might be a good bet since they arent some overinflated #.
