Power supply rec.
dwdty9
535
I need a recommendation for a good, quiet, power supply to power everything I have. My Radeon 9800 Pro seems to be lacking from my 250w ps, even though it's been like that for 9 months. Also, the thing is, my case is a micro-ATX case, one from HP, so I don't know if that makes a difference or not however.
AMD Athlon XP 2800+
1024MB PC2700
Asus ASUS N8X nForce2 400 MHZ FSB
Sapphire Radeon 9800 Pro
80GB Ultra DMA HD
Lite-On 48x24x28 CD-RW
Hauppage WinTV PVR 250
HP f1503 LCD flat panel
tallman45
1,463
Look at the Seasonic Super Tornado. I have the 350w and it runs a 3000+ A64, 1gb, 2xhdd, optical, 6600GT and draws less than 120watta at idle. Super efficiency conserves a lot of energy. Peak output is 390watts.
And dead silent
Zepper
18,998
You usually can't fit a high-powered power supply into those HP micro cases as they take an unusually small sized PSU. 250W is the most I've seen that will physically fit.
.bh.
