Power Supply Question
Blurry
932
Is 320w powersupply enough for this?
Amd Xp 2000+
MSI motherboard
Gainward Geforce 3
Lite On 16x DVD
IBM 80gig HDD
Several Fans
Zim Hosein
Super Moderator | Elite Member
65,385
406
You should be just fine as long as it's a well made PS. BTWm when you say "several fans," how many do you mean Blurry?
bozo1
6,364
All depends on the specific powersupply. If it can put out 30A or more on the 5-volt line, you should be fine. Some 300-watters do, many do not.
