Power supply question
How important is it to have a 300W power supply? I'm running a dual-celeron 366 in a BP6 with about 7 fans, cd-rom, cd-burner, network card, sound card, and a voodoo3. I'm using a 250W supply right now, is that good enough? Thanks for the info guys.
300w is more important on Athlon systems then Intel ones,if your system is working OK & stable then don`t` worry about it yet, but if you intend to use more hardware on your PC then the extra power supply of a good 300w may come in handy,remember if it is not broken don`t try to fix it just yet.
