Does anyone know what power supply is included in the Enlight 7233 that sells at Egghead and if it is AMD approved? And also where are most of y'all gettin your En 7237's from? I can't figure out where to buy one from that has an AMD approved power supply.
Directron is one of the places that lists whether or not cases are Athlon approved. My dealings with them have been positive. They have a couple of Enlight cases, it does not list them as Athlon approved.
