power supply question
Nov 7, 2004
185
right now i have 450watt power supply can the company of it affect the performance of my computer and games???
i got my power supply with my case
this is the case
Text
Twigstir
64
A bad power supply can do all kinds of bad things to your computer including damaging other componets.
Post the specs of your computer so other might help you better. The specs of your system make a difference.
Nov 7, 2004
185
my specs
WINDOWS XP PRO
CPU Type- Intel Pentium 4HT, 3000 MHz (15 x 200)
Motherboard Name- Asus P4C800-E Deluxe
Motherboard Chipset- Intel Canterwood i875P
System Memory- 1024 MB (DDR SDRAM) ULTRA pc3200
Video Adapter- RADEON 9700 PRO (Omega 2.5.97) (128 MB)
Audio Adapter- sound blaster 24bit
Disk Driver- Maxtor 6Y060L0 (60 GB, 7200 RPM, Ultra-ATA/133) 2MB C
Gamingphreek
11,679
No offense, but you got ripped off.
That PSU probably has really weak rails, a lot of fluctuation, and probably can barely make it to 300Watt of power.
I would definately upgrade to a quality PSU.
-Kevin
Nov 7, 2004
185
can someone show me a good power supply?? for under 50dollars ????
i want to get evga 6800gt .. would my power supply hande it??
LTC8K6
28,520
1,575
If it's running well and is stable, then leave it alone. There is no reason to replace your power supply.
fstime
4,382
Thermaltake 420 watt. Under 50. Running it right now with 11.92 12V rail, A64,3 hardrives, 6800nu.
Nov 7, 2004
185
my power supply runs great ... im running 3 neons and 4 led fans .. i didnt have any problems .. but will it work with my new 6800gt??
LTC8K6
28,520
1,575
There is no reason to think it won't.
The 6800GT only calls for a 350watt supply.
zerocool84
36,041
472
well quality really does matter cus i had a 430W cheapo psu that came with my case. was very unstable but now i have a quality one its all gravy now
modedepe
3,474
I personally wouln't run a 6800 GT with a generic PSU. There is too much risk of it blowing and taking the card with it, plus all your other stuff.
Gamingphreek
11,679
Originally posted by: MuDDoG
ok i just ordered Thermaltake 420 watt.
Do you even care what advice we give. I specifically advised to NOT get TT. Why even post and ask a question??
TT's are noisy, they have horribly weak rails, and have poor quality (Ie Small Heatsink, and capacitors).
They are strictly for entry level computers that want a little bit of flash.
-Kevin
Gamingphreek
11,679
Give me a sec... neweggs sight appears to be having problems right now.
I have to leave for work... however, i will post back around 8:30PM EST with several better PSU's.
-Kevin
