Power Supply question...
TheNiceGuy
1,569
Hello. If you can help, it would be greatly appreciated.
I bought this PSU: [edit for working translated link]
http://216.239.37.104/translat...sonic/SS-HS/SS-HS.html
for my system below. I am getting some 'low power' warnings at startup for the GPU (details here):
http://forums.anandtech.com/me...9&threadid=1488362
The PSU 12V=29A, but its split between two rails, so the mobo is only getting 14 or 15A (I guess). Since the GPU feeds only from the mobo, I guess thats the problem.
So is there a way (adapter or otherwise) to combine the 2 rails?
biostud
20,247
7,369
have you plugged in the molex connector on the video card?
BTW 1st linky not working
LTC8K6
28,520
1,576
Do you have the square 4 pin ATX 12V power connector on the mobo hooked up?
If not, that connector is a way to provide more power to the board.
Biostud, no connector on 6600GT.
biostud
20,247
7,369
OK :)
Ah, only on the AGP boards an extra plug is needed
LTC8K6
28,520
1,576
The EZ plug is there in case you don't have an ATX 12V connector. It allowed you to use a regular drive connector instead.
You don't need both the EZ Plug and the ATX 12V connector plugged in.
LTC8K6
28,520
1,576
N/M, it seems ASUS has has changed the function of the EZplug since SLI boards came out. It used to be a substitute for the ATX 12V connector on older boards.
Well, it's only supposed to be used in SLI mode, so maybe you can try unplugging it and see what happens?
TheNiceGuy
1,569
Hi LTC8K6-
I tried without the molex. The Volt readings in ASUS Probe dropped a bit lower. I'm really stuck here.
Duvie
16,215
In dual rail systems such as my OCZ it shows 2 but from what I read the total is still the 2 combined....
Maybe it is a power issue and just a crappy PSU...like most say the wattage rating is a marketing scam...the opnly time you could achieve the actuall 400 wats would be to have the power supply be at 25-20c or less...since that is not normal and most run near 40c you probably rae only getting 70% of that. Start adding up all the power needs of the indivual devices and maybe you are the cusp....
TheNiceGuy
1,569
hmmm... well how about the Antec True 430? No conflicts with this board?
BTW: would this be an RMA issue?
biostud
20,247
7,369
Seasonics are high quality PSUs, although it could be a faulty one.
TheNiceGuy
1,569
It is very weird. If both rails are geting to the mobo, then I should be getting 29A, way above what the ASUS manual recommends as a minimum. Even at 50%, my PSU should be sufficient.
tcxoman2
4
NSPIRE NSP-450P4LF12 450W
http://www.computerhq.com/NSP_...artinfo-id-506161.html
I got this supply and it is great. Supplies over 30A on the 12V1 and 12V2 lines combines. It has a 24 pin ATX2 connector plus the 4 pin 12V connector and another 6 pin 12V connector for SLI. It will also plug right into any motherboard made for the 20 pin ATX if there is space for the connector to extend beyond motherboard connector. No adaptors are required.
