Okay, I was on the computer this morning doing pretty much of nothing and AsusProbe starts alarming. First is was telling me that the 3.3Volt reading was dropping to around 1-3V, then the 12Volt reading was dropping to low reading, and to top that off the +5V starting dropping as well. My Vcore is set to 1.776.
I have a Antec True Power 430 Power Supply, with an Asus A7N8X Deluxe MB, AMD 2400 CPU, 1 Gig of Corsair RAM, DVD Rom, Burner, Fan Bus, floppy, two hard drives, two 92mm fans and three 120mm fans (before you ask what I have in my rig).
Now, the whole time this thing was alarming and beeping, the system was running without any errors or lockups what-so-ever. I finally restarted my computer and everything seems fine now. Note: I did turn my system off for about 3 minutes to look at the caps on the MB since I have heard people having problems with leaking caps but found none.
So....was Asus Probe 2 just freaking out or do I have a serious power supply problem. Has this happened to anyone else? It hasn't started freaking out since I rebooted, in fact everything is stable as can be. Also, my temps were absolutely normal during all of these strange voltage readings.
Thanks for any input.
Cal
Cal
