Power Supply Question
juggernut
I am looking for a good power supply that I can use for a barton system currently but eventually an intel setup and I want to overclock. I need something that will support a lot of devices min 6. I have no clue about power supplies so any advice will be helpfull.
Thanks.
Well, you'll want to get an Antec TruePower then, because they have an inordinate amount of outputs. Link to newegg's Antec power suppy page. Also, they are very stable, because the 3.3v rail and the 5v rail aren't combined, like they are on almost all cheaper psu's. It's the most popular psu used around here. Although, if you don't mind spending quite a bit more money, the Zalman psu's are supposed to be good, also.
edit: I would recommend getting at least the 430watt TruePower, especially since it's only $6 more than the TruePower 380.
Yea I have an antec 430 not sure what one it is all I know is that its the quiet one. The only down side to it is it has two sata power plugs, and that does me no good with out sata drives.
