Does anyone know the method of testing power supplies where you connect two of the leads in the ATX connector together? After you connect these leads and turn the switch for the power supply on, the fan in the back should come on. I have a question though: Should the fan stay on? Or should it just come on for a few seconds and turn off? The power supply I suspect of being bad is doing the second one right now and I just wanted to see if anyone knew about it. Thanks in advance.
