I have a Antec TrueBlue 480 watt power supply in my old case and I looked online to see that the +12v rail is rated at 28amps. I thought that this would be good enough for my new A8N-SLI that just arrived. However, I just pulled out the power supply from my old system and it turns out that I must have purchased one of the early models (I bought it when it first came out a couple of years ago) because the label on the side says that the +12v rail is only rated at 22amps.
I have been reading about the power supply issues with the A8N-SLI and I know I need to have a good power supply. So do you think this power supply will have enough amps to power the following system:
1 - BFG 6800 GT PCIe (possibly upgraded to 2 cards 6 months to a year from now)
1 - IDE dvd-rom
1 - IDE dvd/cd-burner
2 - IDE hard drives
1 - sata hard drive
1 - PCI sound card
1 - floppy
6 - USB devices
winchester 3200
various case and chipset fans
Or should I purchase a new Power Supply? If so, what do you recommend?
Thanks,
Gixxer
1 - IDE dvd-rom
2 - IDE hard drives
1 - sata hard drive
1 - PCI sound card
1 - floppy
6 - USB devices
winchester 3200
Thanks,
Gixxer
