Power Supply Q
A Casual Fitz
4,649
1,018
Athlon 64 X2 4200+
6800GT
1GB of RAM
Would a 350W power supply be enough? Only running at stock speeds.
Moved to Power Supplies
AnandTech Moderator
Gillbot
Zepper
18,998
Sure, and I have just the thing. Please, click the link to my FS/T thread in my sig, below.
.bh.
Billb2
3,035
70
86
There are 350 watt PSU/s that are less useful than a merkin, just as there are 750 watt PSUs that are also junk. Whatever wattage you need, get a good one.
Lunyone
482
This would be probably be the absolute lowest I'd go. It's energy efficient and is quite cheap right now, especially since there isn't a MIR. It has 27A on the 12V rail and could even run an 8800gtx (see my link in my signature to see).
Antec earthwatts EA380 ATX12V v2.0 380W Power Supply 100 - 240 V UL, CUL, FCC, TUV, CE, CB, C-tick, CCC - Retail
http://www.newegg.com/Product/...x?Item=N82E16817371005
If you have a bigger budget than a Corsair vx450w PSU would be better w/33A on the 12V rail and it also has a 5 yr. warranty!
Corsair VX 450w Power Supply - CMPSU-450VX
http://www.buy.com/prod/corsai...loc/101/205466485.html
$75 shipped - $10 MIR - $10 Google Checkout = $55!!!
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
Originally posted by: A Casual Fitz
Athlon 64 X2 4200+
6800GT
1GB of RAM
I assume you're asking because you already have the 350W PSU in your posession.
The answer would be: Depends on the 350W and it's age.
