Power supply probs
Instadeth
Hello, this is my first message on this forum.
I have a strange problem with my power supply, and I was wondering if anyone had experienced similiar.
I am building a PC with second hand parts I got from Ebay etc. so I got a new supply for it. It is a Hiper HPU-4S435 supply (435 Watts). So far so good. So I tested the supply in this PC I am using to write this message, it is an Athlon XP2100 with a 300W supply. The PC would run maybe for 2 or 3 seconds or 20 - 30 seconds before shutting down. Sometimes it would not switch on at all. I have built several PCs before but have never experienced anything like this - can anyone help?
The problem is that if the new supply can't power this low power machine, how is it gonna handle a higher power machine (for which it is intended). Is it because of different ATX standards or something? My old supply has -5v the new one has not. Will it be okay in a more powerful machine or does it sound seriously flawed? Does the Asus A7N8X Deluxe mobo require -5V?
Thanks in advance.
try a differnt PSu wiht the -5v,It may be a bad mobo. Do you have stand off under neath the mobo, try it on card board out of the case maby its gettign shorted soem ware
No this motherboard (Jetway) is okay and properly installed, has been running for years. It is the new PSU I am having trouble with, with this motherboard. I will try it with the A7N8X later on today and let you know how I get on.
It is all set up and runing. -5V is not required. The PSU works OK with the A7N8X MB (the "new" MB). Sorry about any confusion in my original post - The old MB was a different one that apparantly did require -5V.
