http://www.kricomputer.com/shop/?page=shop/pg_pic_left&product_id=129&category_id=ede91dc6e96100c2bd821e76cda26156
This is my case
There is a support bracket that holds the powersupply in. I bought the high end vantec power supply but it is too long. I need a standard sized PS in the 450W+ range. I will be running 8X U160 hard drives in a raid 5 array.
please take note of the position of the support bracket It is screwed directly into the side of the case and is about 2.5 inches in height. It blocks the power wires or fan in some power supplies.
I want to get an enermax ps but I don't knopw if the bracket wil get in the way.
The problem is that I want to use the support bracket. only 1 screw is used and some sort of simple locking technique is used to install the bracket. I can not change the position of the support bracket.
This is my case
