I have a Shuttle motherboard with an Athlon 1.4 in it.. it also has a single 256MB DIMM, 2 IDE HD's connected, an extra fan, an SB Live!, and an ATI All In Wonder AGP. It previously worked fine with a 250W power supply. I then blew that power supply and was using one of my roommate's spare power supplies and everything worked perfectly. I recently moved and returned his power supply and purchased a 250W power supply and had nothing but problems. I tried several other power supplies but encountered similar problems, all of them 250 or 300W. The problem is that the computer will only power on and STAY on if I remove the AGP card and do NOT connect power to the hard drives (but it is fine if the IDE cables are connected). As soon as I connect power to either or both drives or insert the AGP card, I turn on the power, the fan spins up for a brief second, then the power turns off. Any ideas what the problem could be?
