Power Supply Output Question.
IceT
I read Anand's review for various brands of power supplies and I want to know how to calculate a power supply's "theoretical" output (me physics dummy). Also, do you need to use a device to measure the "actual" output of a power supply?
Thanks in advance!
Don't know about calculating the theoretical output, but I'm pretty sure that you can check the "actual" by using a motherboard monitoring software. They can tell you what the voltage is.
