Hi
I am building my 1st pc and have the following assembled so far:
- MSI 865PE Neo2LS motherboard
- GEIL PC3200 DDR memory
- Albatron GeForce 4 Ti4200 AGP graphics card
- Intel 2.4c CPU with heat sink and fan
- Case with Duro 400W switching power supply
I have everything except memory and graphics card plugged into the case. When I connect the cord of the power supply to the mains, nothing happens, the power supply fan moves about 1 cm and then stops, CPU fan does not move.
Yes, I did connect the 20-pin cable from the PS to the motherboard's ATX power supply connector and also PS's 12V connector to the MB's 4-pin connector that provides power to the CPU. And I have also ensured that the PS is switched to 115V and not 220V.
Am i doing something wrong or is this power supply DOA? Do I need to connect everything (including graphics card and memory) also to the motherboard to test the power supply?
Pls help, I still consider myself a rookie as this is my 1st PC build project....🙂
Thanks in advance,
KG
Thanks in advance,
KG
