Power Supply Not Cutting it on AMD's List--Any Suggestions?!?!
cbuchach
1,164
Seeing so much talk about power supplies and overclocking recently has gotten me thinking that the reason for my overly poor overclock on my BXHA Athlon 1200 may be PS-related. I checked the AMD recommended PS list and found that my PS, a 300W Hipro 300SN Rev 01, is only rated up to a 1000 MHz Athlon!!! Even so, my system has seemed quite stable; however, my ability to overclock has been quite poor. I have a BXHA 1200 MHz Athlon B processor. The highest overclock I can get stable is 1279 (142*9), and I do have decent cooling--an Alpha PAL6035 with a YS Tech Fan and ASII. Since pretty much everyone else with this processor has been able to get a higher overclock than I, might it be the PS that is holding me back?
What would you all recommend then as a replacement if it is a PS problem? I know my MB supports PS fan speed monitoring, so it might be nice if the PS had a provision for this. I know I have seen the Enermax Whisper 350 EG365-VE at Coolerguys.com; however, I did not see this PS or any Enermax PS listed on AMD's approved list. Any other suggestions on good power supplies or good places to buy them from?
I guess I have one thing to add and a question of sorts. Does the fact that my PS as stated not being rated higher than 1000 MHz mean that the PS can't provide power to something more than an Athlon 1000, or does it mean that AMD has not tested the supply with more than an Athlon 1000?
I think this type of question has been proposed once before on the forums. Perhaps AMD should specify somehow before I go out and spend $70 on a new PS
Thanks
LuNoTiCK
4,698
Get the enermax. It works very nice, just because it's not on AMD's recommended list doesnt mean nothing. It is better than all the others. Antec is also a good choice but enermax is better. I think AMD took the Iwill KK266 off their recommended list, and read anand's choice for kt133a, he says it's one of the best if not the best. Most everyone who has it is happy with it including me. I have an enermax power supply and it's working fantasically.
cbuchach
1,164
Well, my system is stable now, and I would only upgrade to a more powerful PS if many of you think it might improve my luck with overclocking. What's the verdict? Has upgrading power supplies ever helped anyone improve overclocking?
I have done some more shopping and found a nice Enermax 431W PS at newegg for $80.
