So since I put my computer together in late May 2006, everything has been fine with the exception of my power supply. (ENERMAX Whisper II EG465P-VE FMA(24) ATX12V 460W) From the very moment my PC turned on, the power supply emitted a high-pitched whine. It stopped after a minute or two and I figured it was fine. Throughout the months, however, the whine would start up again and last for hours unless I turned it off. (Which I did many times, as I was afraid of something getting short-circuited.)
I couldn't figure a pattern, it just comes and goes. The only difference now is that it sounds like the fan is stuttering. The voltages appear to be stable. I figure it's time to replace it unless there is something I can do to fix it, which I doubt.
Should I go for the exact same make/model, or should I go for a different PSU altogether?
