Power supply makes noise after upgrade
Insomniator
6,294
171
Hey everyone I just went to a SB build and my corsair 650tx now makes a weird noise whenever I'm in game.
Its definitely from the PSU... and it comes and goes instantly as I minimize/maximize a game. Seems like it only happens under heavy load. This did not happen with my c2q setup...
I cant describe the sound, it kind of sounds like electric waves... like a transformer or something. Sometimes it is a clicking. Any ideas?
Zap
22,377
7
Try disabling anything that says "Spread Spectrum" in BIOS/UEFI. Alternately if they are disabled, try enabling them.
Insomniator
6,294
171
Whats the specs of your rig? Any overclocking being done?
i2500k @ 4.2/auto
Asus P8P67 (UEFI)
GTX 470 @ 800/1600/1800/1.075v
8GB DDR3 1333
1 HD, 1 DVD
5 or 6 case fans
650 should be fine...
I will try that when I get home!
Insomniator
6,294
171
Changing the Spread Spectrum settings did not help =/
Someone in another thread here had the same problem.. Coil whine? System doesn't draw any more power now than it did before the upgrade though...
zod96
2,872
68
If possible get a new PSU that has a good return policy, like no re stocking fee and install it in your new system and see if that gets rid of the problem. I did and my buzzing went away, it was my corsair psu 620hx that was going bad...
