DSF
I'm planning on a fresh build around December of this year.
I currently have a Corsair HX520 that's been powering a pretty standard gaming rig.
E4500 with a mild OC
GTX460 (upgraded from 8800GT)
1 HDD
A couple fans
The PSU's 5-year warranty will run out right around the time I plan to build the new machine. I've heard both sides of the reusing a PSU argument. The new machine is likely to be a midrange gaming machine just like the last one. Mild OC on a mid-level or budget chip, mid-range gaming card, 1 HDD.
Should I feel comfortable continuing to use the Corsair or should I plan on buying a new PSU for the new machine? Or should I split the difference and use the Corsair for a while, and then replace it when I, say, upgrade the video card down the road.
1 HDD
A couple fans
