Power Supply, it is enough?
Question, I have a Enlight case with a 350 watt power supply. I want to add another case fan but with all I have in my computer how will it hold up? Is there a formula that I can use to figure this out?
Thanks
Yeah, you should be fine. I've got a 300 W PSU and 3 hdd's, dvd, cdrw, and all the normal cards and junk. Plus 4 case fans. No problem.
i'm not sure how to add up the power requirement since you don't go by the total needed vs. the total available. it's a bit more complicated since each line has its own total available. i hope i didn't confuse you so i'll just answer your question...
yes, 350watts is plenty...add that case fan, heck, add 10...you shouldn't have a problem
